TCP packet filled with 'U' 1392 bytes long
I'm trying the RL-ARM tcp/ip stack on a arm7 LPC2368 from ETT (futurlec).
I succeed setting up a TCP listen socket with the EasyWeb API.
But when I try to use the TCP stack from RL-ARM 4.12 I don't succeed.
When the controller goes online, it send one packet (ARP notify) and it is filled with 'U' (55) the whole frame/packet, 1392 bytes long.
If I try to setup a TCP connection from my controller to the PC.
several packets as described above appear.
Any idea?
Kind Regards.
  • This is the code I used:
    On flashmagic I have set Osc. freq to 48.0 Mhz
    #include <stdio.h>
    #include <RTL.h>
    #include <LPC23xx.H>                          /* LPC23xx definitions         */
    #define MCLK 48000000                         /* Master Clock 48 MHz         */
    #define TCLK       10                         /* Timer Clock rate 10/s       */
    #define TCNT (MCLK/TCLK/4)                    /* Timer Counts                */
    void delay(unsigned long int);
    void init(void);
    U16 tcp_callback (U8 soc, U8 evt, U8 *ptr, U16 par);
    void procrec (U8 *buf);
    static void timer_poll (void);
    U8 socket_tcp;
    U8 rem_ip[4] = {192,168,3,68};
    int main()
       init();
       init_TcpNet ();
       socket_tcp = tcp_get_socket (TCP_TYPE_CLIENT, 0, 30, tcp_callback);  /* Initialize TCP Socket and start listening */
      // tcp_listen (socket_tcp, 300)          ;
            tcp_connect (socket_tcp, rem_ip, 300, 0);
        while(1)
              timer_poll ();
              main_TcpNet ();
    void delay(unsigned long int count1)
      count1 = count1 * 11000;
      while(count1-- > 0){ }
    static void timer_poll ()
      // System tick timer running in poll mode
       if (T1IR & 1)
          T1IR = 1;
         // Timer tick every 100 ms
          timer_tick ();
    void init()
       /* Timer 1 as interval timer, reload to 100ms. */
       T1TCR = 1;        // Timer[1] = 100mS Trigger
       T1MCR = 3;
       T1MR0 = TCNT - 1;
       if (soc != socket_tcp)
          return (0);
       switch (evt)
          case TCP_EVT_DATA:  /* TCP data frame has arrived, data is located at *par1, */
             procrec(ptr); /* data length is par2. Allocate buffer to send reply.   */
             break;
          case TCP_EVT_CONREQ:   /* Remote peer requested connect, accept it */
          return (1);
          case TCP_EVT_CONNECT:  /* The TCP socket is connected */
          return (1);
       return (0);
    /*--------------------------- Process received data  ------------------------*/
       switch (buf[0])
          case 49:
           break;
Reply Children
