I am trying to run the example code provided in the location C:/Keil/ARM/Boards/Keil/MCB2300/RL/FlashFS/SD_File
I can compile the code and during debugging I have tried to access the files on SD card by giving some commands on Command Window but it does n't accept them.We can also pass those commands using serial window.
I have verified the following link also
http://www.keil.com/support/man/docs/rlarm/rlarm_fs_ex_sd.htm
There it was mentioned that we can enter commands through serial window,but my serial window does n't allow me to type any character.
Please help how to give the commands mentioned in the program like read a file, copy, format etc.,
http://www.keil.com/forum/18169
Please help me and let me know how to run this example (SD_FILE)
It sounds like your problem is still with the Simulator Serial Window, and nothing specifically to do with the SD Card project.
So there's no point in starting a new thread when you already have one open on this subject!
If you feel additional information is relevant, then add it in the original thread: http://www.keil.com/forum/18169
