Open / Select file from Project window
I have found a litle bad habit in the new 4.14.4.0 / 4.14...
if you have all your files closed in the project you can open the file by double click the file in the project window, that is ok.
But if the file allready is open and you double click the file in the project window it will not show/open this file.
I always used this feature becease when many files are open it is hard to find it in the tabs and they can swap place etc...
Do you have some issue in the new release?
Kasper
