Hi frnds....I am using a ADuc831 controller, power supply - OK, oscillator - OK , still i am not able to get any response through UART. wat might be the problem...any idea????
Have you downloaded an application to ADuC's flash?
No, this is a fresh microcontroller , not programmed yet. I am not able to access it through UART. can u plz tell wat check inorder to make sure uC is alive..?
Have you tried powering the unit on?
yes i tried to power on the unit..all the connections are ok., no short ckt of any kind... the reset pin by default is pulled low, i hope it is not a problem ??
