hello there. I need help with multiplexing the 7 segment using 3 digits. Also Im asked to use two 8051 microcontrollers, for voltage and multiplexing respectively. URGENT HELP PLEASE . If i could get a tip for the coding... thank You
Yes: give some indication that you've actually done some work yourself on this.
Where are you stuck?
What help, precisely, do you need?
URGENT
when is your paper due?
