LPC2129 UART ISR Problem
hi,
i try to receive data through UART1 in Interrupt mode, when i run the code the following are the changes occured on reception of the character.
before
U1LSR=0x60
U1IIR/FCR=0xC1
VICVectAddr=0x00000130
VICIRQStatus=0x00000000
VICIntEnable=0x00000080
after
U1LSR=0x61
U1IIR/FCR=0xC4
VICVectAddr=0x00000144
VICIRQStatus=0x00000080
but the coding written in the U1ISR is not invoked. here is my code
#include <stdio.h>      /* prototype declarations for I/O functions */
#include <lpc21xx.h>    /* LPC21xx definitions */
void U1ISR(void) __irq;  //Declare UART1 IRQ ISR
int data,clear,dummy;
long int data1;
void DefISR(void)__irq {
VICVectAddr=0;          /* Acknowledge Interrupt*/
int main (void)
PINSEL0 = 0x00050000;       /* Enable RxD1 and TxD1      */
IO1DIR = 0x00FF0000;            /* P1.16..23 defined as Outputs */
IO1CLR= 0x00FF0000;                 /* turn off LEDs */
U1IER = 0;      /* Disable UART1 Interrupts */
U1LCR = 0x83;   /* 8 bits, no Parity, 1 Stop bit */
U1DLL = 97;     /* 9600 Baud Rate @ 12MHz VPB Clock */
U1LCR = 0x03;   /* DLAB = 0 */
U1FCR = 0x07;   /*Enables and Resets FIFO, 1 byte */
dummy = U1IIR;  /* Read IrqID - Required to Get Interrupts Started */
U1IER = 0x01;   /*Enable the RDA interrupt*/
VICVectAddr7 = (unsigned long)U1ISR; //Set UART1 ISR Vector Address
VICVectCntl7 = 0x20 | 7;     //Enable Slot, Set Channel 7
VICIntEnable = 0x80;         //Enable Int UART1
VICIntSelect =0xFFFF7F;
VICDefVectAddr = (unsigned long)DefISR;     // un-assigned VIC interrupts
while (1)
}       //END OF WHILE LOOP
}       // END OF MAIN LOOP
void U1ISR(void)__irq  //UART1 ISR
data1=VICIRQStatus;
clear=U1LSR;     //UART Line Status Register
data = U1RBR;    //     UART Receiver Buffer Register
data<<=16;
IO1CLR=0x00FF0000;
IO1SET=data;               /*Displaying the DATA on GPIO1 */
VICVectAddr = 0;                /* Acknowledge Interrupt */
return;
please indicate the problem in my code
