What Is the real CCLK referenced ? (used for IAP and FlashFS)
Hardware : MCB2300 Board (LPC2378)
Xtal : 12Mhz
I read on some post that the CCLK to set in the IAP code is 12000 (KHz)
http://www.keil.com/forum/10740/
When I give a look at the LPC_IAP2_512 project in the fs_init() function I see that for LPC23XX devices CCLK is set to 4000 (KHz)
But I think that conforming to the user manual §4 fig 16 the CCLK is CPU clock after going from Xtal (if selected) * PLL * CPU Clock divider.
If I look at the default config in LPC2300.s I see that the PLLCFG Multiplier is 12 and divider is 1, and the CCLKCFG divide by 6.
So
CCLK = (1/6) x (12/1 x 2) * XtalCLK = 4 x XtalCLK
Freq(CCLK) = 1/4 Freq(Xtal) = 3 MHz
So we should put in the IAP fs_init() or IAP routines CCLK = 3000. Right ?
Or this CCLK is not the "user manual definition".
