Customized bootloader to program HEX file
I am trying to write a customized boot loader application on LPC2478. The bootloader application reads the hex file stored in a memory device and programs the on chip flash memory using IAP routines. the test application resides at location 0x60000. After the chip programming is complete the bootloader is supposed to jump to 0x6000 using "(*((void(*)(void))0x60000))();"
The problem i am facing is
1>. Even though the bootloader successfully programs the flash 0x6000 onward, which i have read using flash magic, the application refuses to start.
2>. I have no clue of what to do with record types "01" and "05" which i have encountered in my hex files.
3>. If i program the same hex file that i programmed using my bootloader using flash magic [both bootloader and hex file resides at this time] , the application runs successfully.
4>. I tried to read the entire chip memory [0x0000 to 0x7DFFF containing boot loader and test application both] using flash magic and saved to a file then re-programmed using flash magic, and the same test application runs.
A>. kindly someone let me know what is to be done when record type 01 and 05 is encountered.
B>. Is there some sacred data that is to be written on chip after which the bootloader operation would be considered complete so that an application runs.
