I am using LPC 1114,with 12Mhz crystal frequency...
How can I get 9600 baud rate .....?
Please tell me how to use clock sources to get that baud rate?
Didn't the user manual for the processor clearly show how to compute the values to program into the baudrate generator?
... and doesn't the chip manufacturer provide any examples?
Maybe Keil provide some examples - have you checked...?
Download the access baudrate calculator from the NXP site!
I have checked user manual and using sample codes given by ARM.
The following is my code , give me any suggestions ....
/***************************************************************************************/ #include "LPC11xx.h" #define IER_RBR 0x01 #define IER_THRE 0x02 #define IER_RLS 0x04 #define LSR_RDR 0x01 #define LSR_THRE 0x20 void UARTInit(unsigned int Baudrate); void UARTSend(void); void UARTRecv(void); void delay(void); volatile unsigned char RECV; int main (void) { UARTInit(9600); while (1) { UARTRecv(); UARTSend(); } } /*=========================================================================================*/ void UARTInit(unsigned int baudrate) { unsigned int regVal; unsigned int Fdiv; LPC_IOCON->PIO1_6 &= ~0x07; /* UART I/O config */ LPC_IOCON->PIO1_6 |= 0x01; /* UART RXD */ LPC_IOCON->PIO1_7 &= ~0x07; LPC_IOCON->PIO1_7 |= 0x01; /* UART TXD */ LPC_SYSCON->SYSPLLCTRL = (1<<3)|(1<<6); LPC_SYSCON->SYSAHBCLKCTRL |= (1<<12); // UART CLK enable LPC_SYSCON->UARTCLKDIV = 0x2; /* divided by 1 */ LPC_UART->LCR = 0x83; /* DLB=1, 8 bits, no Parity, 1 Stop bit */ regVal = LPC_SYSCON->UARTCLKDIV; Fdiv = (((12000000/1)/regVal)/16)/baudrate ; /*baud rate */ LPC_UART->DLM = Fdiv/256; LPC_UART->DLL = Fdiv % 256; LPC_UART->LCR = 0x03; /* DLAB = 0 ,Disable access to divisor latches*/ LPC_UART->FCR = 0x07; /* Enable and reset TX and RX FIFO. */ regVal = LPC_UART->LSR; /* Read to clear the line status. */ return; } void UARTSend() { lcd_str("in snd"); delay(); LPC_UART->THR = RECV; // for my testing i'm sending recd cahr+1 value while ( !(LPC_UART->LSR & 0x40) ); //wait until TEMT=0,i.e. U0THR contains valid data } void UARTRecv() { lcd_str("in recv"); while(!(LPC_UART->LSR & (0x01))); RECV=LPC_UART->RBR; //Store the char received in to a variable } /****************************************************************************************/
with this code , I am getting simulation output. In simulation I'm getting baud rate other than 9600.
I am using Xtal freq: 12Mhz
Please help me......
So what baud rate, exactly, are you getting? How do you determine that?
What investigations have you done to try to account for the difference?
