Dear All,
I am trying to add a boot loader for my LPC2478 based application. I want to conditionally Branch to my main code at 0x1000 from the boot loader code. When i tried from Startup.s as below
IMPORT __main ; LDR R0, =__main LDR R0, =0x1000 BX R0 it worked fine. Now the problem is that I cannot do the same from main().
This does not compile int main(){
__asm{ LDR R0, =0x1000 B R0 }
generating following errors...
boot.c(8): error: #29: expected an expression boot.c(8): error: #1097: Expected a [ or ] boot.c(9): error: #114: label "R0" was referenced but not defined
PLS HELP...THANKS
A jump to an absolute address in C can be as simple as "((void (*)(void))0x1000)();"
Depending on the compiler, optimisation, etc, that could give you a call rather than a jump...
