HI I AM FACING ONE PROBLEM IN LPC2294 CUSTOM BOARD. I CAN ABLE TO ERASE AND PROGRAM THE DEVICE. BUT IF I TRY TO DEBUG, SOFTWARE CONTROL IS NOT ENTERING IN MAIN FUNCTION. (24 MHZ CRYSTAL, PLL IS DISABLED). HOW DO I FIX IT? THANKS IN ADVANCE...
Turn off the god damn caps lock and we'll talk !
IF U HAVE ANY SOLUTION TO THIS PROBLEM REPLY ME. DON'T WASTE YOUR TIME (AND MY TIME ALSO). AND DON'T GIVE THIS KIND OF REPLY.
NOTE: DAMN....WHAT IS YOUR PROBLEM IF CAPS LOCK IS ON?
It's actually your problem - you just don't get any help while shouting, since people don't read your posts.
When you meet a group of unknown persons in an unknown city - do you start by shouting at them when asking for help, or do you do your best to fit in? In some neighbourhoods, shouting might get you a knife where you don't want one. But maybe you're a fighter?
Text written in ALL-CAPITALS is hard to read.
Writing in ALL-CAPITALS is often considered to be "SHOUTING" and, therefore, rude.
Why did you think that writing in ALL CAPITALS would be a good thing to do?
You got some very good advise so far. Is your program reaching "main" yet?
Disable "Run to main" in your debugger and see what goes wrong before the uC reaches main. Fix the problem. Done.
THANK YOU. PROBLEM IS SOLVED BY MYSELF. U ALL WELCOME AND WE WILL MEET AGAIN.
