LPC3250 HSUART HELP
Hi I was unable to get data properly through High Speed uart's. as per my program i was able to get only 64 bytes properly after that not getting. Here i am posting the program Please take a look and give me the Directions
Thank You
int main(void)
        unsigned char i;
        init_HSUART1();
   while(1)
         //HSUART1_senddata(HSUART1_receivedata());
          HSUART1_senddata('1');
          HSUART1_senddata('2');
          HSUART1_senddata('3');
          HSUART1_senddata('4');
          HSUART1_senddata('5');
void init_HSUART1 (void)
  HSU1_RATE     =192;// baud rate 115200 for 13MHz CLK
  HSU1_CTRL= 0x00001C00;
**      DESCRIPTION     :       This function waits until its receives a character from the terminal.
**      RETURN          :       Character received from the terminal
unsigned char HSUART1_receivedata(void)
        unsigned char gch;
        while((HSU1_RX&0x0100)==0x0100);            //cheak for data availability
                gch = HSU1_RX;                                          // Storing data into temp variable 'gch'
                return(gch);                                            // Return the data
**      DESCRIPTION     :       This function transmits the given character to the terminal.    *
**      RETURN          :       None        *
void HSUART1_senddata(unsigned char pch)
        HSU1_TX=pch;
//      while((HSU1_IIR&0x01)==0x01);
                        // Transmiting data into buffer
/*      if((HSU1_LEVEL&0xFF00)==0x0400)
        while((HSU1_LEVEL&0xFF00)==0x0000);
        else{}
        return ;
        /*if((HSU1_IIR&0x01)==0x01)
         HSU1_IIR|=0x01;        // Clear or ACK the interrupt
        HSU1_TX=pch;            // Transmiting data into buffer
    return;     */
