HOW TO GIVE INPUT VALUES TO DATAPOINTER USING MEMORY. MY PROGRAM IS NOT TAKING IN ANY VALUES GIVEN @DPTR.</b >
If I understood your question I believe I could answer
"more words do not make you appeat stupid, it makes you appear clear"
C or assembly?
an example of your code, maybe some 'code' that show what you want even though the assembler/compiler will not accept it
typing in all capitals and bold does not make you get an answer faster, in fact some may not respond for that reason
oh fine......assembly programming...we tried out our Keilc just today...so when we gave the particular DPTR value in the program it never got executed and an error was generated on that particular instruction.......answers for this question ????
stop using multiple dots......stop using bold.....use ##### instead######.............
on that particular instruction last post from me if I see bold, .... or all capitals
IMO use of ##### is just as bad.
What is wrong with learning to do it properly?
And it is too hard to figure out that # is in this situation meant as a wildcard character? Not any of the more spread wildcard characters used by traditional grep but some programming frameworks have been using # when defining match patterns for input fields in dialogs.
"And it is too hard to figure out that # is in this situation meant as a wildcard character?"
There is no doubt that the originator would (now) concur.
oh cmon guys i never knew all these rules ill try to change myself , my answer pls ??
What is the question?
It would help if you explained the problem clearly and, if appropriate, provide a snippet showing the problem.
i never knew all these rules ill try to change myself I posted; "which instruction" is that too difficult to answer or are you just too busy making your posts look 'fancy' and thus do not have time to answer questions?
Do not "try to change" STOP SHOUTING (yes, I SHOUT that, trying to get it through your skull).
Stick to the simple, you have to do extra operations to make your post SHOUT (bold/capitals) and very few people (including me) like getting shouted at
Erik,
Wanna bet his next post would be in bold?
I DONT WANT ANY REPLIES FROM U
Wanna bet his next post would be in bold? naah, I know I'd lose.
isn't it amazing that when the kids ask for free advice it always comes with "I give you only whatever information I see fit in whatever form I prefer and you better give me the answer NOW in the form I want. Do not dare to ask me anything just answer, if I have not given enough information, since you do this for free, what do I care if it takes you a long time to figure out what I mean. Also it is more importand that my post show my 'individuality' than it is that it is readable"
You may substitute whatever word you see fit for 'individuality' above
