Library mysery
I have a piece of proprietary code that absolutely needs to be included in the project as a library. The problem is, that once the .lib file is included, the controller hangs (abort, or not - RTX driven system) after about a minute or operation (library installs a UART ISR). If I replace the library with the only source file used to build it - there is no problem at all! Did you encounter something similar with MDK? Any ideas?
By the way, how can one contact support? I'm being redirected to this ARM site, I registered but nothing happened...?
