I have a piece of proprietary code that absolutely needs to be included in the project as a library. The problem is, that once the .lib file is included, the controller hangs (abort, or not - RTX driven system) after about a minute or operation (library installs a UART ISR). If I replace the library with the only source file used to build it - there is no problem at all! Did you encounter something similar with MDK? Any ideas? By the way, how can one contact support? I'm being redirected to this ARM site, I registered but nothing happened...?
I think the 'Contact' link (bottom left of page) may contain a clue...
Aha...!
By the way, I moved my ISR outside of the library (it calls a library function), and increased the size of my UART hardware buffer. Did not see hangups since, but I remain doubtful. If the ISR is placed inside the library, practically nothing helps! Smells like a tool-chain issue to me. I will try to write a test application in my free time (what is that?). By the way, there are quite some issues with MDK 4.12 that are pending a solution (C runtime library etc.).
Remember that having the ISR in the library affects the linking order, so also order of variables - if you have a buffer overflow, it's important to know what other variables follows the overflowing buffer.
