#include <AT892051.H> #include <stdio.h> #include <intrins.h> sbit DigitShiftregisterSerialPin=P1^0; /* Character to be transfered through thisbit in parallel*/ sbit DigitShiftregisterClockPin=P1^1; /* Clock*/ sbit DigitShiftregisterLatchPin=P1^2; /* Latch*/ /*sbit DriveMinutes=P1^3; /* 1st 7-segment Display*/ /*sbit DriveTensMinutes=P1^4; /* 2nd 7-segment Display*/ /*sbit DriveHours=P1^5; /* 3rd 7-segment Display*/ sbit DriveTensHours=P1^6; /* 4th 7-segment Display*/ unsigned char SevenSegmentData; unsigned char _crol_(unsigned char Temp,unsigned char SevenSegmentData); char Display_Buffer[1]; int Dispcount; int mscount; int Hours=1; int Minutes=0; int Seconds=0; char Temp; code unsigned char DecimalToSevenSegment[11]= { 0xEE,0x28,0xCD,0x6C,0x2B,0x67,0xE7,0x2C,0xEF,0x2F }; void main() { TMOD=0x01; TH0=0xF8; /* Initializing timer0 for 1ms*/ TL0=0x30; IE=0x82; TR0=1; do { sprintf(Display_Buffer,"%02d%02d",Hours); /* converting integer into character*/ }while(1); } void Timer0(void) interrupt 1 /* ISR begins*/ { TF0=0; TR0=0; TH0=0xF8; TL0=0x30; TR0=1; { /* To transfer bits into byte from port pin onto the shift register*/ Dispcount++; /* Dispcount is used to refresh the Hours and Minutes on the LED*/ mscount++; /* Generate 1ms Delay*/ if(++mscount>=1000) { mscount=0; Seconds++; } if(++Seconds>=60) { Seconds=0; Minutes++; } if(++Minutes>=60) { Minutes=0; Hours++; } if(++Hours>=13) { Hours=1; } } // For DriveTensHours LED { int i,j; if(Dispcount==29) /* This code is for refresh rate of DriveTensHours*/ { /* DriveMinutes=0; DriveTensMinutes=0; DriveHours=0; */ DriveTensHours=0; } if(Dispcount==30) { if(j<=1) { SevenSegmentData=DecimalToSevenSegment[Display_Buffer[j]-0x30]; if(8>i) /* For a byte to be read by the port pin*/ { if (Dispcount==32) { Temp=SevenSegmentData; } if (Dispcount==34) { DigitShiftregisterClockPin=1; /* clock is set high*/ /*}* /*if (Dispcount==36)*/ /*{*/ DigitShiftregisterSerialPin=Temp^7; /* Taking MSB one at a time, the loop continous till all 8-bits are sent to the portpin*/ /* } if (Dispcount==38) {*/ DigitShiftregisterClockPin=0; /*clock is made low*/ } if (Dispcount==40) { SevenSegmentData=_crol_(Temp,1); /* bits are rotated left*/ } DigitShiftregisterLatchPin=0; /* Data is Latched*/ } if(Display_Buffer[0]) { DriveTensHours=1; } } } } }
