asin function on LPC1768
Hello
I am using LPC1768 for a motor control application. The motor will be
controlled with a series of pulses each of 2us wide.
I use a asin function to calculate the time between two pulses. (The
motor moves clock and anti-clock wise, hence a sin function is
considered)
when asin function is called, the code tends to break. ie it gets stuck
at hardware handler routine.
I believe the issue is with the use of asin function, although i am not
sure about it. I am using inbuilt asin in math.h
Can anyone kindly suggest me how to use a asin function on LPC1768. If
anyone can provide me a small code for how to use it on LPC1768 would be
of great help.
I have tried the code on rowley crossworks and on Keil. Both seem to
give the same error. But in simulator asin function is working fine.
Kindly suggest.
Regards
Prakash
