Hello all, I am currently working with AT89C51CC01.One can see the Datasheet from the following link.
www.atmel.com/.../doc4129.pdf
My work is to make program which gives PWM as output. Just check this code. #include <stdio.h> #include "reg_c51.h"
#define PWMPIN P1_0
unsigned char pwm_width; void pwm_setup(); void timer0();
void main(void) {
pwm_setup(); PWMPIN = P1_7; //timer0(); while(1); }
void pwm_setup() { TMOD = 0; pwm_width = 200; EA = 1; ET0 = 1; TR0 = 1; }
void timer0() interrupt 1 { if(!F0) //Start of High level { F0 = 1; //Set flag PWMPIN = P1_7; //Set PWM o/p pin TH0 = pwm_width; //Load timer TF0 = 0; //Clear interrupt flag return; //Return } else //Start of Low level { F0 = 0; //Clear flag PWMPIN = 0; //Clear PWM o/p pin TH0 = 255 - pwm_width; //Load timer TF0 = 0; //Clear Interrupt flag return; //return } }
I had write this code in Keiluvision4 and after making hex file, i open hex file using Flip 3.4.1 and load whole
file into controller and check the o/p using oscilloscope. I set p1_7 pin for PWM o/p, but when i test this program then it gives nothing on p1_7 pin. wht is the problem in this program? Pls give ur advice for this problem.
Thank u in advance.
if you would post your code formatted (the instructions are right over the 'reply' field, I might have a look. Asking free help to decipher unformatted code is, in effect, saying "my time is valuable, yours is not"
