SMT32 usb two HIDs
working with the SMT32 processor, I've some troubles with the usb interface. I want to install two HID interface descriptors (each has one endpoint - endpoint1 and endpoint4).
In the device manager of my computer, I get two usb HID interfaces - which sounds good; but there's only a communication with the endpoint1 not with the endpoint4!
void USB_EndPoint3 (DWORD event) {
This function will be never called!
I tried to debug the code and I found out that at the beginning I get a Set-Address command with the addr 0x86 (which sounds good for these two endpoints); after that the host reads the usb device descriptor and the string descriptors; after that dataoutstage function is called, but the EP0Data.pData is 0x00...
void USB_DataOutStage (void) {
  DWORD cnt;
  cnt = USB_ReadEP(0x00, EP0Data.pData);
  EP0Data.pData += cnt;
  EP0Data.Count -= cnt;
After that an reset event occured; I don't know why...
And the whole process will start from the beginning; except that the endpoint4 won't be configurated again; that means Set-Address command includes only the first endpoint1 but not the endpoint4!
At the moment I've no idea where the problem could be!
void USB_Configure_Event (void)
  unsigned char InReportKeyboard[5];
  unsigned char InReportTouch[6];
        //es werden nur demo packets an die inputs geschickt keien richtigen daten
        memset( &InReportKeyboard[0], 0, sizeof(InReportKeyboard) );
        memset( &InReportTouch[0], 0, sizeof(InReportTouch) );
  if (USB_Configuration)
  {                  /* Check if USB is configured */
        USB_WriteEP(0x81, InReportKeyboard, sizeof(InReportKeyboard));
        USB_WriteEP(0x84, InReportTouch, sizeof(InReportTouch));
Do someone know if this function is correct with these two USB_WriteEP calls?
These are my descriptors:
const BYTE USB_ConfigDescriptor[] = {
/* Configuration 1 */
  USB_CONFIGUARTION_DESC_SIZE,       /* bLength */
  USB_CONFIGURATION_DESCRIPTOR_TYPE, /* bDescriptorType */
  WBVAL(                             /* wTotalLength */
    USB_CONFIGUARTION_DESC_SIZE +
    USB_INTERFACE_DESC_SIZE     +
    HID_DESC_SIZE               +
    USB_ENDPOINT_DESC_SIZE              +
        /* interface two: descriptor length */
        HID_DESC_SIZE                           +
  0x02,                              /* bNumInterfaces */
  0x01,                              /* bConfigurationValue */
  0x00,                              /* iConfiguration */
  USB_CONFIG_SELF_POWERED //USB_CONFIG_BUS_POWERED /*|*/       /* bmAttributes */
/*USB_CONFIG_REMOTE_WAKEUP*/,
  USB_CONFIG_POWER_MA(0), //USB_CONFIG_POWER_MA(100),          /* bMaxPower */
USB_INTERFACE_DESC_SIZE,           /* bLength */
  USB_INTERFACE_DESCRIPTOR_TYPE,     /* bDescriptorType */
  0x00,                              /* bInterfaceNumber */
  0x00,                              /* bAlternateSetting */
  0x01,                              /* bNumEndpoints */
  USB_DEVICE_CLASS_HUMAN_INTERFACE,  /* bInterfaceClass */
  HID_SUBCLASS_NONE,                 /* bInterfaceSubClass */
  HID_PROTOCOL_NONE,                 /* bInterfaceProtocol */
  0x5E,
HID_DESC_SIZE,                     /* bLength */
  HID_HID_DESCRIPTOR_TYPE,           /* bDescriptorType */
  WBVAL(0x0100), /* 1.00 */          /* bcdHID */
  0x00,                              /* bCountryCode */
  0x01,                              /* bNumDescriptors */
  HID_REPORT_DESCRIPTOR_TYPE,        /* bDescriptorType */
  WBVAL(HID_REPORT_DESC_SIZE),
USB_ENDPOINT_DESC_SIZE,            /* bLength */
  USB_ENDPOINT_DESCRIPTOR_TYPE,      /* bDescriptorType */
  USB_ENDPOINT_IN(1),                /* bEndpointAddress */
  USB_ENDPOINT_TYPE_INTERRUPT,       /* bmAttributes */
  WBVAL(0x0008),                                         /* wMaxPacketSize (muss so groß sein, dass das kompl. pkt reinpasst an daten */
  0x25,
  0x01,                                  /* bInterfaceNumber -> zweites interface im configuration descriptor  */
  0x01,                              /* bNumEndpoints -> wieviele endpoints besitzt dieses interface */
  0x00,
  WBVAL(HID_REPORT_DESC_SIZE_2),
  USB_ENDPOINT_IN(4),                /* bEndpointAddress */
  WBVAL(0x0008),                      /* wMaxPacketSize (muss so groß sein, dass das kompl. pkt (report descriptor) reinpasst an daten */
  0x20,
/* Terminator */
  0                                  /* bLength */
best regards
Jan
  • Moved from SiLabs USB forum, because the target MCU is STM32, and the firmware is based on KEIL example.
    www.cygnal.org/.../002075.html
    A brief summary of the discussion on above thread,
    1) The OP observed bus reset and Clear_Feature( ENDPOINT_HALT ) for EP4, after enumeration finishes.
    It was thought as error recovery sequence for EP4 by the host HID class driver.
    This problem was solved by changing the USB_EP_NUM value on usbcnfg.h
    usbcnfg.h
    #define USB_EP_NUM          2 // <---- 5 ( = 1 + 4 )
    2) Revised report descriptor was proposed for the first HID interface, which provides system keyboard.
    // Report format
    //   Input report - 1 byte
    //     byte   value
    //      0     0: not pressed, 1: Space bar, 2: Down arrow, 3: Up arrow
    //   Output report - 1 byte
    //     byte
    //      0     0x00 - 0xFF
    //   Feature report - HID_FEATURE_REPORT_BYTES
    //     byte
    //      0     0x00 - 0xFF
    //      HID_FEATURE_REPORT_BYTES - 1
    const BYTE HID_ReportDescriptor[] = {
        HID_UsagePage( 0x01 ),           // Generic Desktop
        HID_Usage ( 0x06 ),              // keyboard
        HID_Collection ( HID_Application ),
                                         // --------- common globals -----
            HID_ReportSize  ( 8 ),       // 8 bits
            HID_LogicalMin ( 0x00 ),     // value range: 0 -
                                         // --------- input report -----
            HID_LogicalMax ( 0x03 ),     // value range: 0 - 3
            HID_ReportCount ( 1 ),       // 1 byte
            HID_UsagePage( 0x07 ),       // Keycode page
            HID_Usage( 0x00 ),           // key null - not pressed
            HID_Usage( 0x2C ),           // Space bar
            HID_Usage( 0x51 ),           // Down arrow
            HID_Usage( 0x52 ),           // Up arrow
            HID_Input ( HID_Data | HID_Array ),
                                         // --------- output report -----
            HID_LogicalMaxS ( 0xFF ),    // value range: 0 - 0xFF
            HID_UsagePageVendor( 0x01 ), // Vendor specific page
            HID_Usage ( 0x01 ),
            HID_Output ( HID_Data | HID_Variable | HID_Absolute ),
                                         // --------- feature report -----
            HID_ReportCount ( HID_FEATURE_REPORT_BYTES ),
            HID_Usage ( 0x01 ),
            HID_Feature ( HID_Data | HID_Variable | HID_Absolute ),
        HID_EndCollection,
    This report descriptor is under testing on the OP side.
    3) Four options are proposed for the second HID top-level collection for touchscreen
    a) Generic Desktop - Mouse
    b) Generic Desktop - Joystick (or GamePad)
    c) Digitizer page - Pen (or Touchscreen)
    d) Vendor specific device
    Tsuneo
Reply Children
