SMT32 bootloader / application
using a SMT32F103 processor, I want to install an bootloader as well as an application. Two different projects, so that the bootloader (usb) is able to erase / update the application on this processor.
Is it possible to debug the application when the bootloader is starting first?
Is this a proper way to jump from the bootloader app to the application?
// switch to supervisor mode so that stacks in the next startup file can be set (once is
// user mode, only an exception can bring the processor out of it. SWI is such an exception.)
void __swi(0) jump_to_application_code(void);
void __SWI_0  (void)
    void   (*lp_application_start)(void);
    // interrupt vectors are mapped using the RAM_INTVEC REMAP RAM_MODE macros in the ASM tab of uv3
    lp_application_start = (void (*)(void))APPLICATION_FLASH_START;
    lp_application_start();
int main(void)
        jump_to_application_code() ;
Do I have to do additional things for the normal application? for example: that all interrupts will work in the application?
best regards
Harald
