I am using a STM3210E-EVAL baord with uVision4 as my development tools.
There are project configuration Options for the Target where "Read/Write Memory Areas" can be defined. For the STM3210E-EVAL there is external RAM starting at 0x68000000. There is 512KbitX16, which is about a 1 megabyte (0x100000).
After enabling this external memory area the processor will not jump to main. Why would this not work? The "NoInit" check box is not set.
The processor jumps to the HardFault_Handler routine. However, this is after going into "__main". I'm not exactly sure what is inside of "__main". There is a startup file in 'C:\Keil' that shows the following:
; Dummy SystemInit_ExtMemCtl function SystemInit_ExtMemCtl PROC EXPORT SystemInit_ExtMemCtl [WEAK] BX LR ENDP ; Reset handler routine Reset_Handler PROC EXPORT Reset_Handler [WEAK] IMPORT __main LDR R0, = SystemInit_ExtMemCtl ; initialize external memory controller BLX R0 LDR R1, = __initial_sp ; restore original stack pointer MSR MSP, R1 LDR R0, =__main BX R0 ENDP
What is suppose to go into 'SystemInit_ExtMemCtl' assembler routine? I have a fsmc_sram.c file that performs this intialization.
What happens inside of '__main' when you specify off-chip memory?
Where could I find this information?
did you make sure that it not jumps to an abort? If peripherals are not (properly) enabled, the processor could jump to an abort handler.
See startup.s file in project.
. BR, /th.
