GCC build problems
I'm having trouble adapting a Makefile-based build to uVision 4 for my cortex-m3 target. I have (I think) all the compile settings pulled in, but the link is failing on some libc-related stuff. I'm using the latest GCC 4.5.0-based yagarto toolchain, and seeing the link error:
c:/yagarto/bin/../lib/gcc/arm-none-eabi/4.5.0/../../../../arm-none-eabi/bin/ld.exe: error: Source object c:/yagarto/bin/../lib/gcc/arm-none-eabi/4.5.0/../../../../arm-none-eabi/lib\libc.a(lib_a-memset.o) has EABI version 5, but target buildtest.elf has EABI version 0
c:/yagarto/bin/../lib/gcc/arm-none-eabi/4.5.0/../../../../arm-none-eabi/bin/ld.exe: failed to merge target specific data of file c:/yagarto/bin/../lib/gcc/arm-none-eabi/4.5.0/../../../../arm-none-eabi/lib\libc.a(lib_a-memset.o)
I've confirmed that in the Makefile build, it's linking against arm-none-eabi/lib/v7m/libc.a instead, and I've definitely specified -mcpu=cortex-m3. Any tips on why the uVision-based build wants to link against arm-none-eabi/lib\libc.a?
Secondary issue
Is it possible to view the full build output? Currently, the only output I see is summarized: "compiling syscalls.c..." etc. I realize that the tabs in the project settings show what is going to be passed to the compiler, but I'd sure like to see it happening myself so I can diagnose problems a little more easily.
Thanks!
