i would like to display the numbers in LCD, i am using a count button, for each increment upt o 9 i am able to display after that i have problem, following is the code i used
;***********subroutin NUMBER MOVLW 2 ;enables the display MOVWF PORTA MOVLW 3H MOVWF PORTB CALL CLOCK MOVF COUNT,W ; count is the vasriable from the push button MOVWF PORTB CALL CLOCK ;clock character onto display. RETLW 0
;*******display*************
MSG15 ; NUMBER DISPLAY MOVLW 0CH ;Cursor on second line, C3 CLRF PORTA MOVWF PORTB CALL CLOCK MOVLW 04H MOVWF PORTB CALL CLOCK CALL NUMBER ; is from soubroutin CALL DELAY RETLW 0
;************main program
i call MSG15 ; to display
And why are you repeating yourself, and creating a new thread?
What was wrong with this thread? http://www.keil.com/forum/docs/thread16740.asp
Same thing that's wrong with this thread: if it's assembler, it cannot possibly be generic - it must be specific to a particular architecture!
It's the same thing as the original thread which also specified "Generic".
