hai,
I had written a code in following way
#include <REGX55.H> #include <math.h> #include "DEFINE_H.h" void delay(unsigned int);
main()
{ while(1) { HEALTH = ~HEALTH; delay(65535); delay(65535); } }
void delay(unsigned int count) { while(count) count--; }
In DEFINE_H.h i had declared the HEALTH = p3_4 ;
BUT WHEN COMPILING THE PROJECT IT IS SAYING THAT HEALTH IS UNDEFINED IDENTIFIER. BUT I HAD DEFINED IN THE DEFINE_H HEADER FILE AND I HAD INCLUDED HEADER FILE IN A MAIN.C
You failed to notice the clearly-stated instructions that tell you how to post source code:
www.danlhenry.com/.../keil_code.png
People reading your post may overlook that error, and try to make sense of your post - but a Compiler will not.
When the compiler says something is "undefined", it means, more precisely, that there is no valid definition; ie, what you wrote was not valid as a definition.
Check your code very carfully to make sure that it is precisely correct and you have followed every rule in minute detail!
Did the compiler also report any other errors?
