How do modify the RL-TCPnet to suite the POP3 Client?
It seems that RL-TCPnet does not support POP3 Client?
What do you mean by "support" here?
It seems clear from the description that RL-TCPnet does not provide a ready-made POP3 Client: http://www.keil.com/arm/rl-arm/rl-tcpnet.asp
But that doesn't mean that it can't support one that you provide yourself...
These protocols are all Layered: so you would build the POP3 layer upon the TCP and IP "foundations" provided in RL-TCPnet - or any other TCP/IP stack, for that matter...
I am new to TCP/IP Stack.
Is there any application notes about the POP3 Client from RL-TCPnet?
Any one can help on POP3 using TCP from RL-TCPNet?
I do not have the library you mentioned. But it seems trivial by looking at this page. (http://www.keil.com/support/man/docs/rlarm/rlarm_tn_using_tcpsoc_example.htm)
www.faqs.org/.../rfc1939.html
