I have tested Keils RTX Program EX1.c using Lpc2124 using the Debugger and everthing ran OK.
So I modifed the EX1.c Prog for the LPC 2368. 1) Used LPC23xx.h through-out. 2) Removed Startup.s and used lpc2300.s and modifies the SWI Handler as described by Keil. 3) set T1TCR to 0 before os_init.
Started the Debugger and displayed OS-Support-> rtx-kernel it shows: task 1 wait_or " " 0000 0004 36% (ie no delay is shown, wait for event) task 2 wait_delay 2 " " " " 32% (ie no events expected) idle_os_demon 0%
There is no task switching going on.
Looking at Clock dividers the CCLK regularly changes from 48 to 2 MHz and back again...and this appears to me ti be wrong, but cannot find out why. I have a suspicion that the reset handler is being called.
I'm using the Keil Demo V4 uVision on Win XP.
Can any one help me out to locate the problem?
Bonzadog
Removed Startup.s and used lpc2300.s<i/>
why?
you only needed to import SWI_Handler, actually! this step is most likely the reason for your program's resets. have you forgotten that you are using an LPC21xx, not a LPC23xx?
do you really believe you can just build a program with arbitrary startup up code and it will run? why not then use a .s file of a Pentium...?
duh. bcoz pentium is not arm architecture.
duh. bcoz
Oh, yeah.
No i don't believe that. If you read further you would have seen that the task does doest initialied and started so very obvioulsy the startup there.
I used the lpc2300.s and modified it for the SWI Handler, as described in the RTX Doc. startup.d doesn't work as well. I had tried that.
Then then I have been observe that the system seems to go to the reset_handler - perhaps from the timer...
