I have STM32F107VCT6 board,ST-Link debugger and Keil microvision3 IDE.My chip is not listed in device database.How can I add this device to the list?Is there any document which describes how to setup and debug the STM32MCB with St-Link Jtag thru keil Microvision? I tried sometime to figure out this and could not find any.
Please help me in this
Thanks Rama
http://www.keil.com/support/man/docs/uv4/uv4_ca_cpu_ndatabase.htm
Thanks a lot for your reply.
Now I could add the device. I then want to write one file to the flash memory thru STLink Jtag.After selecting other parameters in Project->Options for target, when I click flash->Download, it gives error that "No CPU DLL specified under Options for Target-Debug1". What is this?How should I proceed?
Could any one please help me in this?
Any update on this?
Did you try the latest MDK version? MDK v.4.10 should fully support your chip and ST-Link.
Hi, Thanks a lot for your input.
I have installed the 4.10 version and now the options are available for stm32f107vc and STLink JTAG.When I tried the Blinky example under keil/arm/board/st/, I am seeing the message "The detected STLink firmware is out of date. Upgrade to v9 is recommended."
Moving further and giving F5 also, I don't see the LED"s blinking. The debugger and flash utility is selected for STLink JTAG.
What I am missing?
Please help.
I have an ST-Link and it works, did you try to upgrade the ST-Link firmware as suggested? I'm sorry but I have no idea where to find the v9 upgrade...
Here it is...
www.st.com/.../familiesdocs-110.html
Thank you very much. I were able to execute examples in my board using the STLink JTAG :)
