I'm triyng to simulate an external interrupt with the LPC378 but it doesn't work.
I already saw other threads about this problem. It seem's to work with MCB2100 with a .ini file but it doesn't work with the MCB2300 (LPC2378). What can I do ?
I try it with µV3 and µV4 ! Here is my source code :
#include "LPC23xx.h" void isr_EINT0 (void) __irq { FIO2PIN0 = ~FIO4PIN0; /* alternate the LED display */ EXTINT = 0x01; /* clear interrupt */ VICVectAddr = 0; /* Acknowledge Interrupt */ } void init_EINT0(void) { PINSEL4 = 0x00100000; /* set P2.10 as EINT0 and P2.0~7 GPIO output */ FIO2DIR = 0x000000FF; /* port 2, bit 0~7 only */ FIO2CLR = 0x000000FF; /* turn off LEDs */ EXTMODE = 0x01 ; /* INT0 edge trigger */ EXTPOLAR = 0; /* INT0 is falling edge by default */ VICVectAddr14 = (unsigned)isr_EINT0; /* set interrupt vector */ VICIntEnable = (1<<14); /* Enable Interrupt */ } int main() { init_EINT0(); /* Call function to initialize EINT0 */ while(1); }
And my simulation .ini file :
// // Generates a number of pulses on GPIO 2.10 // signal void GPIO_2_10_Square (unsigned int pulses) { float frequency; // pulse frequency in Hz frequency = 10; // 100 Hz printf ("%d Square Pulses on GPIO 2.10\n", pulses); while (pulses) { PORT2 |= (1 << 10); // set pin 2.10 swatch (0.5 / frequency); PORT2 &= ~(1 << 10); // reset pin 2.10 swatch (0.5 / frequency); pulses--; } } GPIO_2_10_Square (100); // 100 Pulses at debugger startup define button "EINT0 1 Pulse", "GPIO_2_10_Square (1)" define button "EINT0 100Pulses", "GPIO_2_10_Square (100)"
Best Regards, Yann
