I use uV 4.00 in an project using the LPC2939 from NXP. In uV 4.00 in debug mode the peripherals dialog is empty and I can't see the register information for the peripherals. Does anyone know how to resolve the problem?
Thank you!
- Frank
Frank; I notice that this device is not yet fully supported at this time. Check this at the following link.
http://www.keil.com/dd/chip/4810.htm
You can move forward by selecting a similar device that is more fully supported. The code structure will be the same, just the peripherals and their access will be limited. By moving through the LPC2917 thru the LPC2919/01, I'm sure that most of the LPC2939 peripherals would be supported. I don't know this to be true but it's worth a bit of your time to look at build your first code on one of these alternate devices and then finishing up with the LPC2939 selected.
Bradford
