I have a code for USB mass storage device on atmel AT91SAM7SE512 target. The code is based on Keil\ARM\Boards\Atmel\AT91SAM7X-EK\RL\USB\RTX_Memory .
When connecting my device to a PC and saving a file - I see that at some point, messages are sent to endpoint task from ISR (isr_mbx_send...) but not received by the endpoint task (os_mbx_wait...). Some save sessions are passed successfully, but most sessions behave as described above...
Any idea what may be the problem...?
Since isr_mbx_send does not return any value, you might not know, if the message has been send.
http://www.keil.com/support/man/docs/rlarm/rlarm_isr_mbx_send.htm
If the mailbox is full, the kernel ignores the message since it cannot be put into the mailbox. Thus before sending a message using isr_mbx_send, you must use the os_mbx_check function to check if the mailbox is full. [There is failure in the manual, it should be isr_mbx_check.]
Do you check the mailbox with isr_mbx_check?
Currently I check the mailbox with os_mbx_check (as done in the mentioned reference code) and according to the return value - mailbox is available... When should I use os_mbx_check and when isr_mbx_check..?
In an ISR, you should use isr_mbx_send() and obviously then also isr_mbx_check().
I'm using now isr_mbx_check but there is no change in the behavior.
Can you post the code of the ISR and the receiving function?
The ISR code:
/* Endpoint Interrupts */ for (n = 0; n < USB_EP_NUM; n++) { if (isr & (1 << n)) { csr = pUDP->UDP_CSR[n]; /* Setup Packet Received Interrupt */ if (csr & AT91C_UDP_RXSETUP) { pEpEvent = _alloc_box (USB_MsgPool); /* allocate memory */ if (pEpEvent){ pEpEvent->bCnt = USB_ReadEP(n, pEpEvent->bData); /* read the setup packet */ pEpEvent->wEvent = USB_EVT_SETUP; /* set event */ if (isr_mbx_check (USB_EPMbx[n]) == 0) _free_box (USB_MsgPool, pEpEvent); else isr_mbx_send (USB_EPMbx[n], pEpEvent); } Udp_ep_clr_flag(pUDP,n,AT91C_UDP_RXSETUP); } /* Data Packet Received Interrupt */ bkm = RX_DATA_BK[RxDataBank[n]]; if (csr & bkm) { pEpEvent = _alloc_box (USB_MsgPool); /* allocate memory */ if (pEpEvent){ pEpEvent->bCnt = USB_ReadEP(n, pEpEvent->bData); /* read the data packet */ pEpEvent->wEvent = USB_EVT_OUT; /* set event */ // Save isr_mbx_check result for debug mbxCheck = isr_mbx_check (USB_EPMbx[n]); if (mbxCheck == 0){ _free_box (USB_MsgPool, pEpEvent); mbxErr++; // Debug } else { isr_mbx_send (USB_EPMbx[n], pEpEvent); // Debug- count the bulk out (EP 2) data messages if ((pEpEvent->bCnt == 64) && (n==2)) EP_2_Count_Sent++; } } Udp_ep_clr_flag(pUDP,n ,bkm); if (DualBankEP & (1 << n)) { RxDataBank[n] ^= 1; } } /* Data Packet Sent Interrupt */ if (csr & AT91C_UDP_TXCOMP) { Udp_ep_clr_flag(pUDP,n ,AT91C_UDP_TXCOMP); if (TxDataBank[n]) { //pUDP->UDP_CSR[n] |= AT91C_UDP_TXPKTRDY; Udp_ep_set_flag(pUDP,n,AT91C_UDP_TXPKTRDY); TxDataBank[n] = 0; } pEpEvent = _alloc_box (USB_MsgPool); if (pEpEvent){ pEpEvent->wEvent = USB_EVT_IN; if (isr_mbx_check (USB_EPMbx[n]) == 0) _free_box (USB_MsgPool, pEpEvent); else isr_mbx_send (USB_EPMbx[n], pEpEvent); } } /* STALL Packet Sent Interrupt */ if (csr & AT91C_UDP_STALLSENT) { if ((csr & AT91C_UDP_EPTYPE) == AT91C_UDP_EPTYPE_CTRL) { pEpEvent = _alloc_box (USB_MsgPool); if (pEpEvent){ pEpEvent->wEvent = USB_EVT_IN_STALL; if (isr_mbx_check (USB_EPMbx[n]) == 0) _free_box (USB_MsgPool, pEpEvent); else isr_mbx_send (USB_EPMbx[n], pEpEvent); } } Udp_ep_clr_flag(pUDP,n ,AT91C_UDP_STALLSENT); } } }
The receiver task code:
void USB_EndPoint2 (void) __task { T_USB_EP_EVENT *pEpEvent; USB_EPMbx[2] = USB_EP2Mbx; /* store Mbx in array */ os_mbx_init (USB_EP2Mbx, sizeof(USB_EP2Mbx)); /* initialize the mailbox */ for (;;) { os_mbx_wait (USB_EP2Mbx, (void **)&pEpEvent, 0xFFFF); /* Wait for an Event */ memcpy (BulkBuf, pEpEvent->bData, pEpEvent->bCnt); /* store received data from mailbox */ BulkLen = pEpEvent->bCnt; // Debug - update counters if ((BulkBuf[15] == 0x2A) && (BulkLen == 31)) { printf("\n --> BulkOut zero counter %d (writeCount = %d) ", bufOutCount, writeCount); bufOutCount = 0; writeCount = 0; } else if (BulkLen == 64) bufOutCount++; MSC_BulkOut(); _free_box (USB_MsgPool, pEpEvent); /* free memory allocated for message */ } }
In the error case - I eventually receive Bus reset from host and then I print the session counters: CBW.dDataLength = 29184, - Length of data that was sent (/64 = 456) EP_2_Count_Sent = 420, - Number of bulks sent by ISR bufOutCount = 388, - Number of bulks received by receiver task writeCount = 388, - Number of bulks handled by SW mbxErr = 0 , - No mailbox request errors mbxCheck = 28 - Number of available mailbox entries
(Each Bulk is 64 bytes)
May it be possible, that
fails and therefore the message is not even created. There is no error checking for this case, as far as I see.
The next line checks that aloccation was successfull ( if (pEpEvent){...). If allocation failes - the mailbox send code is not activated... See that my counter is promoted only after successfull allocations and when mailbox is available
