using IAP for flash writing with working ethernet
I use lpc2378 and can write to flash with IAP, but if I have working ethernet (based on easyweb sample) then...
then a number of things occure exept normal work.
Anybody uses write data to flash with ethernet ?
  • Hi,
    Can you please explain your situation more clearly?
    Specifically, what does this mean: "then a number of things occure exept normal work"?
    I am using the IAP interface to flash my LPC2468 (with TCPnet) successfully via Ethernet. However, I do run into some problems when trying to flash the portion of my ROM that TCPnet resides in. As a temporary solution, I have assigned TCPnet its own section of ROM and simply not flashed over that.
    -Eric
  • Hi,
    -Eric
