I am looking to buy a microcontroller board along with a dev kit that could handle processing a live video feed (Assuming 60 fps at 320x280 pixel density). I guess I am looking for a microcontroller that has a clock speed of above 600 Mhz.
Can anyone recommend me any good microcontroller boards for this application?
Could you define "processing"? The amount of CPU power required for, say, image sharpening is different from that for realtime encoding or feature extraction.
Hi, if your processing is not very complex you may also use a FPGA only for the image data processing and a controller for the interface/communication/control part.
