difference between and " " for # include
What is the difference between these two sentence:( <> and " ")?
#include <rtl.h>
#include "rtl.h"
  • When you use <> the compiler looks in the compilers standard include directories.
    When you do "" it first looks relative the current directory.
    You should use "" for your include files and <> for header files supplied with the compiler.
    By the way - this is documented in any book about C/C++ programming and also in the language standard. I recommend that you get a good book to read. When done, then get the official language and use as a reference.
