Interrupt stops randomly
Mocroprocessor: AT91SAM7s128
Toolchain: RealView MDK-ARM Version: 3.20
I have the following ADC code need to be run while interrupts disabled to eliminate 60hz noise. So I put it inside SWI (all interrupts are disabled in SWI).
int __swi(1) GetRawCountsFromExternalADC2DataBuffer(unsigned short * P);
int __SWI_1 (unsigned short * P)
    unsigned int Index;
    unsigned int Sum;
    // Start the ADC
    StartPWMC();
    do    // Eliminate first reading
        // Check if the ADC ready for the data
        Sum = CheckADCReady();
    }while(Sum == 0);
    SelectSpiPort(SPI_ADC);
    GetDataFromSpi();
    // Start get 1024 readins
    for(Index = 0; Index < TOTAL_SAMPLE; Index ++)
        do
        }while(Sum == 0);
        *(P + Index) = (unsigned short)GetDataFromSpi();
    // Stop the ADC
    StopPWMC();
    return(1);
The problem is that all interrupts (Timer and UART) will be stopped after it runs for random time. I also
use the spuriouse interrupt handler to fix the problem, but it is not working.
The following code is used to catch the spurious interrupts.
// STORE SPURIOUS INTERRUPT HANDLER TO AIC_SPU
    AT91C_BASE_AIC->AIC_SPU = (unsigned long) SpuriousInterruptHandler;
static void SpuriousInterruptHandler(void)
    // END OF INTERRUPT
    AT91C_BASE_AIC->AIC_EOICR = 0; }
If I am not using disable/enable interrupts for ADC code (data with 60hz will not right), the code runs without any problem.
Any comments are appreciated!
