Hi all,
I was wondering if anyone could shed some light on the behaviour of the external interrupts, especially their flag behaviour.
void int1 (void) interrupt 2 using 2 { P1_4 ^= 1; // Toggle the Green LED EX1 = 0; }
This code toggles our LED on/off if the interrupt occurs. The idea is that the interrupt only occurs once and then we disable it.
With an edge interrupt this code works.
With a level interrupt it doesn't and the interrupt remains enabled, however if I disable it as soon as the interrupt has returned it stays disabled.
I am guessing that in Level mode, I can't clear this flag because the level is still there when I try to clear it and so in hardware the bit is left set? Is this correct?
Ths ASM code shows the bit being cleared and then a correct RETI.
This is only a bit of test code as we are ultimately using this for power down/wakeup.
Cheers for any comments,
Dirk
This is govenred by the behaviour of the hardware, so the place to look is the so-called "bible" for the 8051 architecture - links here: www.8052.com/.../120112
See also: http://www.8052.com/tutorial
