Hi all I have a strange problem when I'm trying to cast buffers by arm compiler. Here an example:
char* pbuf; ... unsigned short val = *((unsigned short*)(pbuf+3));
When I compile this code, my generated assembly code uses LDRH,STRH. Then because my pbuf+3 is not multiple of 2 and those 2 instruction can only work with even value addresses, processor hangs up. What I should to do that compiler generates a code that works in all cases?
Regards
