can u make a counter for 0-9999 with c ?
Is the pope catholic?
plz .i i need code for it. can u give me?
> i got sum code .here it is when u need it. > > for ( i = 0 ; i != 9999 ; i = i + one ) > > ; > > i = 9999 ;
I have a quicker solution:
int i=0; while(i++<9999);
or, the hard way:
int *i=(int *) malloc(sizeof(int)); memset(i, 0, sizeof(int)); while(*i++<9999);
or ... after reading your code ... a much quicker solution:
int i = 9999;
*smile*
BR, /th.
int i=0; while( i++ < 9999 );
Although the source code may be briefer, it is rather unlikely that the generated machine code will be any different at all...
*pssschhhht* ...he doesn't know that! ;-)
Since we're now giving him the answers, here's the one I was going to suggest:
#define TWO 1 ... int i; i = 0; loop: i = i + TWO; if (i > 9999) goto end; goto loop; end: ...
whoops ...
#define Z 0 #define N 9999 #define F for #define I int #define B break #define C if I i=Z; F(;;) C(i++>N) B;
wtf? www.linkedin.com/.../b06
/* **====================================================================== ** My_Counter **====================================================================== ** ** Counts to MAX_COUNT and returns the MAX_COUNT value. ** **---------------------------------------------------------------------- ** ** Parameters Passed: <void> ** Parameters Returned: u16 -- the counted value ** Notes: ** ** 'ramble( )' expands to 9999 words of boredom. ** **---------------------------------------------------------------------- */ u16 My_Counter( void ) { ramble( 9999 ); // lots of comments }
--Cpt. Vince Foster 2nd Cannon Place Fort Marcy Park, VA
You don't say - this is a central part of a guidance system of some kind :-)
So what "code monkey" wrote this, then?
I'm sure your famous book must note somewhere that misleading and/or incorrect comments can often be worse than no comments at all...
But in line with the code quality we expect in this thread, ramble is
#define ramble return random_boring_dictionary_lookups
Yes and every forum I've seen them try it in they get warned not to do it again. Text speak isn't English and people who aren't 'cell' phone infatuated find it so irritating they won't reply to them. They get all bent out of shape if they don't get an answer for days (impatience of youth) then repost. Then they get "no double posting. you must use English in your questions LEET and Cell phone speak is not considered English".
Most people who aren't English speaking are easier to understand than people who use such gibberish. I don't understand why they expect an instant answer either.
Stephen
Thanx Malund Erik U are funny engineer! U said u use SILABS in your projects how do u interface CRYSTAL to your hardware? do u use serial or usb port or I/O card compatible with it? Do u have any manual of it for a beginner person like me! Things that I always like to learn is interfacing my hardware to cores through USB and SERIAL port can u hapl me in this field?
for a new subject start a new thread
I do not know 'U' or is it 'micro' if he is that funny, share some of his jokes
Just a case of improper use of language. Everyone knows that "are" is a one-letter word...
