Hi, i am new to ucontroller programming. I wanted to make some password and 7-segment display projects using 4x4 matrix keyboard as input, in C. I just need some simple example links or sample code or part to understand how to decode the keypad inputs. Thanks in advance.
You can use the Keypad encoder IC
You can use the Keypad encoder IC such as DFL-KEY55A or DFL-Key55B, which can convert the key pressed to RS232. Click on www.dafulaielectronics.com
just a bit of help
keys must be debounced
I knew basic concepts of Digital as well as C programing. That only made me to complete handson on led blinking, 7-segment driving, LCD display driving etc. that too googling myself and some reference books.
Right now i am experimenting with keypad and RS232 serial communication with 89c51. Even again and again going through the code for keypad to understand, i feel difficult to catch every steps. Anyhow i am going through your code. Will try to catch the concept soon. If i have doubt, the only option is asking others experts. Thats wat created the thread in this topic.
In other words, what you don't need is any source code at all!
What you do need is a basic understanding of the principles - irrespective of any processor, programming, or compiler.
You may be better to start looking for books or sites on basic (digital) electronics...
Thanks for your guidence. I searched, i too got 5000 hits, but few sites has huge code structure, and few has very small ones. I gone through the codes also, but cant get easily, since compilers also different. So i thought that i may be wasting time. Then only i came here for help directly for keil. Because its easy for someone to direct me to a nice ones. Then i can read it confidentialy.
www.8052.com/.../167585
But have you really done any serious googling? I get over 5000 hits for "4x4 Matrix keypad 8051" Are you really saying that none of those gives you any help at all?
Even if a site doesn't answer all your questions, it should help you think of better keywords to improve your search.
And don't forget Google's Advanced Search options to further improve your results: www.google.co.uk/advanced_search
Specifically for source code, try http://codesearch.google.com
Note that the techniques for dealing with keypads and 7-segment displays are pretty much independent of what particular processor you use - so any book or site covering such interfacing should be able to help you.
Have you looked at the book list here: http://www.keil.com/books
This site discusses both C and assembler implementations.
I still feel you have level up your Google skills. Do ask specific questions about things you have a problem understanding, instead of expecting full solutions to be sent to you.
Ofcourse i tried, and have sample examples also. But feel little difficult to understand the coding. Thats wat asked here, because if any doubt i can clarify with thier codes easily. Tried in this forum also but got ASM code.
For that reason only i asked part of code. Because experts only can point the specific example for a particular thing to a begginner.
And the number of hits you get if trying Google isn't enough - someone must do the search and report the best links to you?
What about the search function on this site? Didn't try that one either?
