Hey I need to interface the external EEPROM AT24C04 to SILABS (device) plz help me if any one can give me a code in 'C' for that..Thanx for he
Err hmmm maybe you should like at the code examples SI labs gives? Look at the information they give for I2C interfacing etc. I believe you should consider this a little test of your abilities. As for quick working circuit... have you read the data sheets etc? This seems kind of a strange question to ask too me, since there appears to be a massive volume of information already available, having had to do this myself.
Stephen
Hey answerers I looked on the internet web browser but there was nothing today. send me the stuff you got to devesh143657982@yahoo.com
So your claim "now looking for a quick working circuit" wasn't actually correct?
You are not looking for a quick working solution. You are expecting someone else to produce a quick working solution for you...
When is your school assignment due?
"I looked on the internet web browser but there was nothing today."
Oh, come on!
I just put "interface external EEPROM AT24C04 to SILABS" into Google and got 211 hits.
And that's without looking for specific information on the SiLabs o EEPROM manufacturer's websites...
"today"
Oh, yeah. So, did you manage to find something yesterday?
plz send me the links. and i will ignore the jibes.
Err, excuse me?
What, you can't find your own way to http://www.google.com ?
What? Are you saying there is a need to navigate???
Isn't it enough to just start the internet browser and watch what comes up? If nothing suitable today, then maybe tomorrow?
Hallo Devesh,
I have a Program written for PCF8583 RTC which is also using i2c protocol. It is very Complicated and has a lot of good code.
The email address You gave Just bounced me. So, if you are interested i will post here, please let me know.
// PCF8583.C #ifndef PCF8583_SDA #define PCF8583_SDA PIN_C4 #define PCF8583_SCL PIN_C3 #endif #use i2c(master, sda=PCF8583_SDA, scl=PCF8583_SCL) #ifndef PCF8583_WRITE_ADDRESS #define PCF8583_WRITE_ADDRESS 0xA0 #define PCF8583_READ_ADDRESS 0xA1 #endif // Register addresses #define PCF8583_CTRL_STATUS_REG 0x00 #define PCF8583_100S_REG 0x01 #define PCF8583_SECONDS_REG 0x02 #define PCF8583_MINUTES_REG 0x03 #define PCF8583_HOURS_REG 0x04 #define PCF8583_DATE_REG 0x05 #define PCF8583_MONTHS_REG 0x06 #define PCF8583_TIMER_REG 0x07 #define PCF8583_ALARM_CONTROL_REG 0x08 #define PCF8583_ALARM_100S_REG 0x09 #define PCF8583_ALARM_SECS_REG 0x0A #define PCF8583_ALARM_MINS_REG 0x0B #define PCF8583_ALARM_HOURS_REG 0x0C #define PCF8583_ALARM_DATE_REG 0x0D #define PCF8583_ALARM_MONTHS_REG 0x0E #define PCF8583_ALARM_TIMER_REG 0x0F // Use the first NVRAM address for the year byte. #define PCF8583_YEAR_REG 0x10 // Commands for the Control/Status register. #define PCF8583_START_COUNTING 0x00 #define PCF8583_STOP_COUNTING 0x80 char const weekday_names[7][10] = { {"Sunday"}, {"Monday"}, {"Tuesday"}, {"Wednesday"}, {"Thursday"}, {"Friday"}, {"Saturday"} }; // This structure defines the user's date and time data. // The values are stored as unsigned integers. The user // should declare a structure of this type in the application // program. Then the address of the structure should be // passed to the PCF8583 read/write functions in this // driver, whenever you want to talk to the chip. typedef struct { int8 seconds; // 0 to 59 int8 minutes; // 0 to 59 int8 hours; // 0 to 23 (24-hour time) int8 day; // 1 to 31 int8 month; // 1 to 12 int8 year; // 00 to 99 int8 weekday; // 0 = Sunday, 1 = Monday, etc. }date_time_t; //---------------------------------------------- void PCF8583_write_byte(int8 address, int8 data) { disable_interrupts(GLOBAL); i2c_start(); i2c_write(PCF8583_WRITE_ADDRESS); i2c_write(address); i2c_write(data); i2c_stop(); enable_interrupts(GLOBAL); } //---------------------------------------------- int8 PCF8583_read_byte(int8 address) { int8 retval; disable_interrupts(GLOBAL); i2c_start(); i2c_write(PCF8583_WRITE_ADDRESS); i2c_write(address); i2c_start(); i2c_write(PCF8583_READ_ADDRESS); retval = i2c_read(0); i2c_stop(); enable_interrupts(GLOBAL); return(retval); } void PCF8583_init(void) { PCF8583_write_byte(PCF8583_CTRL_STATUS_REG, PCF8583_START_COUNTING); } //---------------------------------------------- // This function converts an 8 bit binary value // to an 8 bit BCD value. // The input range must be from 0 to 99. int8 bin2bcd(int8 value) { char retval; retval = 0; while(1) { // Get the tens digit by doing multiple subtraction // of 10 from the binary value. if(value >= 10) { value -= 10; retval += 0x10; } else // Get the ones digit by adding the remainder. { retval += value; break; } } return(retval); } //---------------------------------------------- // This function converts an 8 bit BCD value to // an 8 bit binary value. // The input range must be from 00 to 99. char bcd2bin(char bcd_value) { char temp; temp = bcd_value; // Shifting the upper digit right by 1 is // the same as multiplying it by 8. temp >>= 1; // Isolate the bits for the upper digit. temp &= 0x78; // Now return: (Tens * 8) + (Tens * 2) + Ones return(temp + (temp >> 2) + (bcd_value & 0x0f)); } //---------------------------------------------- void PCF8583_set_datetime(date_time_t *dt) { int8 bcd_sec; int8 bcd_min; int8 bcd_hrs; int8 bcd_day; int8 bcd_mon; // Convert the input date/time into BCD values // that are formatted for the PCF8583 registers. bcd_sec = bin2bcd(dt->seconds); bcd_min = bin2bcd(dt->minutes); bcd_hrs = bin2bcd(dt->hours); bcd_day = bin2bcd(dt->day) | (dt->year << 6); bcd_mon = bin2bcd(dt->month) | (dt->weekday << 5); // Stop the RTC from counting, before we write to // the date and time registers. PCF8583_write_byte(PCF8583_CTRL_STATUS_REG, PCF8583_STOP_COUNTING); // Write to the date and time registers. Disable interrupts // so they can't disrupt the i2c operations. disable_interrupts(GLOBAL); i2c_start(); i2c_write(PCF8583_WRITE_ADDRESS); i2c_write(PCF8583_100S_REG); // Start at 100's reg. i2c_write(0x00); // Set 100's reg = 0 i2c_write(bcd_sec); i2c_write(bcd_min); i2c_write(bcd_hrs); i2c_write(bcd_day); i2c_write(bcd_mon); i2c_stop(); enable_interrupts(GLOBAL); // Write the year byte to the first NVRAM location. // Leave it in binary format. PCF8583_write_byte(PCF8583_YEAR_REG, dt->year); // Now allow the PCF8583 to start counting again. PCF8583_write_byte(PCF8583_CTRL_STATUS_REG, PCF8583_START_COUNTING); } //---------------------------------------------- // Read the Date and Time from the hardware registers // in the PCF8583. We don't have to disable counting // during read operations, because according to the data // sheet, if any of the lower registers (1 to 7) is read, // all of them are loaded into "capture" registers. // All further reading within that cycle is done from // those registers. void PCF8583_read_datetime(date_time_t *dt) { int8 year_bits; int8 year; int8 bcd_sec; int8 bcd_min; int8 bcd_hrs; int8 bcd_day; int8 bcd_mon; // Disable interrupts so the i2c process is not disrupted. disable_interrupts(GLOBAL); // Read the date/time registers inside the PCF8583. i2c_start(); i2c_write(PCF8583_WRITE_ADDRESS); i2c_write(PCF8583_SECONDS_REG); // Start at seconds reg. i2c_start(); i2c_write(PCF8583_READ_ADDRESS); bcd_sec = i2c_read(); bcd_min = i2c_read(); bcd_hrs = i2c_read(); bcd_day = i2c_read(); bcd_mon = i2c_read(0); i2c_stop(); enable_interrupts(GLOBAL); // Convert the date/time values from BCD to // unsigned 8-bit integers. Unpack the bits // in the PCF8583 registers where required. dt->seconds = bcd2bin(bcd_sec); dt->minutes = bcd2bin(bcd_min); dt->hours = bcd2bin(bcd_hrs & 0x3F); dt->day = bcd2bin(bcd_day & 0x3F); dt->month = bcd2bin(bcd_mon & 0x1F); dt->weekday = bcd_mon >> 5; year_bits = bcd_day >> 6; // Read the year byte from NVRAM. // This is an added feature of this driver. year = PCF8583_
www.silabs.com/.../an128.pdf
