_getkey() + putchar() vs. getchar()
I've written some code for an educational project which tries to capture input from the user, I've noticed that when using the library function _getkey() alone it turns each typed Enter or Intro pressed key into CR ('\r', ASCII encoding = 0x0D), but when using the function getchar(), which is supposed to use _getkey() internally, it turns each typed Enter or Intro pressed key into LF ('\n', ASCII encoding = 0x0A), following I show two small snippets I've used in order to verify this behavior:
1.- Using _getkey() and putchar() to get the job done:
#include <reg515c.h>
#include <stdio.h>
void test_getkey (void) {
  char c;
  while ((c = _getkey ()) != 0x1B) {
    putchar(c);
    printf ("\ncharacter = %bu %bx\n", c, c, c);
void main(void)
        SCON = 0x52;
        BD = 1;
        /* 9600 Bd @ 10 MHz => SMOD = 1, SREL = 0x3BF */
        PCON |= 0x80;
        SRELL = 0xBF;
        while(1)
                test_getkey();
Output when pressing the Enter or Intro key:
character = 13 d
1.- Using getchar() to get the job done:
#include <stdio.h>
void test_getchar(void) {
  char c;
  while ((c = getchar ()) != 0x1B) {
        putchar(c);
void main(void)
        SCON = 0x52;
        BD = 1;
        PCON |= 0x80;
        SRELL = 0xBF;
        while(1)
                test_getchar();
character = 10 a
In the following Support Knowledge Base article:
http://www.keil.com/support/docs/1791.htm
it is stated that by defaul getchar() is implemented as follows:
char getchar (void)
char c;
c = _getkey ();
putchar (c);
return (c);
So I don't understand why the characters read vary when pressing the Enter/Intro key, could somebody please shed some light on this issue?.
Thanks in advance,
Juan
  • Just an amendment to the code I posted, actually the correct programs are:
    #include <stdio.h>
      char c;
        putchar(c);
        printf ("\ncharacter = %bu %bx\n", c, c);
    void main(void)
            SCON = 0x52;
            BD = 1;
            PCON |= 0x80;
            SRELL = 0xBF;
            while(1)
                    test_getkey();
    2.- Using getchar() to get the job done:
    #include <stdio.h>
      char c;
    void main(void)
            SCON = 0x52;
            BD = 1;
            PCON |= 0x80;
            SRELL = 0xBF;
            while(1)
                    test_getchar();
    I hope somebody can help me :)
    Juan
    #include <stdio.h>
      char c;
        putchar(c);
    void main(void)
            SCON = 0x52;
            BD = 1;
            PCON |= 0x80;
            SRELL = 0xBF;
            while(1)
                    test_getkey();
    #include <stdio.h>
      char c;
    void main(void)
            SCON = 0x52;
            BD = 1;
            PCON |= 0x80;
            SRELL = 0xBF;
            while(1)
                    test_getchar();
    Juan
