Modified from your feedback told Sir !
Dear Sir, with the feedback given by you I was able to re-structure my I2C Interrupt routine.Interrupt is invoking properly everytime, but I am not able to get the desired result.
I want to clarify that I am reading data from my master controller.
 My Slave has data like this.
   Location      Value
     0x00 --->    1
     0x01 --->    2
     0x02 --->    3
and so on till 0x23 ----> 24 .
In LPC2368 I have to use SLA+R protocol (Master-Receiver Mode)
Correct ???
If so below is my re-structured irq ...
__irq void I2C_IRQHandler(void)
   switch(I21STAT)    /* Checking each States */
     case 0x08 :     /* Start Condition */
/* My Slave Address is 0x11 , but as we calculate to feed it in      I2C Protcol format we arrive as
                                                   (Read/Write)
   Bit Positions : 7    6    5    4    3    2    1     0
   Slave Address : 0    0    1    0    0    0    1     1 (Read)
Setting 0x11(Slave Address) along with the Read Bit ,I arrive at 0x23 for SLA+R (MASTER RECEVIVE)
        I21DAT = 0x23;  /* Feeding Slave Address SLA+R*/
        break;
     case 0x10 :   /* Repeated Start Condition */
         I21DAT = 0x23;  /* SLA+R */
         break;
     case 0x40 :  /* SLA+R Transmitted ACK Received */
        I21CONSET = 0x04; /*Send ACK from Master */
        break;
     case 0x48 : /* SLA+R Transmitted NO ACK */
       I21CONSET = 0x20;  /* Setting Start bit again */
       break;
     case 0x50 : /* Data Byte Received with ACK*/
       Message = I21DAT /* Reading Data and storing it in global variable unsigned char Message ; */
       I21CONSET = 0x04; /*Return back the ACK bit */
       break;
    case 0x58 : /* Data Byte Received with NO ACK returned*/
      break;
   default :
     break ;
   I21CONCLR = 0x08;    // Clear I2C Interrupt Flag
   VICVectAddr = 0;     // Acknowledge Interrupt
Other than my IRQ routine in my main I use this function
void main(void)
        PCONP |= 0x00080000;
        PINSEL1 |= 0x000003C0;  /* Setting Pin Selection for I2C1 */
        I21SCLL   = 60;         /* Speed at 100Khz  */
        I21SCLH   = 60;
        VICIntEnClr |= (1<<19);
        VICVectPriority19 = 1;
        VICVectAddr19 = (unsigned long)I2C_IRQHandler;
        VICIntEnable |= (1<<19);
 while(1)
        I21CONSET = 0x00000040;  /* Setting I2Enable bit   */
        I21CONSET = 0x00000020;  /* Setting Start Bit */
       if(Message == 1)
          LcdDisplay("Message is 1");
      and so on....till Message == 23..
I have tried placing I2Enable and Start bit outside the while(1) .But still I am not able to get the data from slave .
Please! Please help me on this issue if i was right with the protocol of I2C.
Regards,
Samjith
  • it looks like you are bombarding the bus with start conditions. you need to finish one full transaction, then issue a new one (the next start). you need to make sure that your "Message" variable is synchronized between your ISR and main, but that might be implicitly solved by the first advise you got from me.
