ive got this code and dont know what is wrong.
#define a 1 #define b 2 #define c 3 #define 22 37 #define binary1 0x01 #define binary2 0x02 #define binary3 0x04 #define binary4 0x08 #define binary5 0x09 #define binary6 0x10 #define binary7 0x20 int toggle__pin ( int port , int pin ) { if ( port == a && pin == 1 ) { P0 = binary1; delay(1); P0 = ~binary1; } if ( port == a && pin == 2 ) { P0 = binary2; delay(1); P0 = ~binary2; } // repeated return 23; }
A delay function that is optimized by the compiler...? show it please.
First take at look at your defines....
Everywhere your code has an a it will be substituted, not just where you think it will be.
If you use PREPRINT compiler directive it will give you a list of the code the compiler will see after the #define stuff has been added to your code. This will show you a great deal and teach you a lot about how defines work in your code. Simply, each define must have a unique label
#define PORT_A 1 for eg
"Everywhere your code has an a it will be substituted, not just where you think it will be."
The preprocessor works on tokens, not on individual characters, so the C preprocessor will not replace any a that is part of a longer token or that is inside a C string.
