Using Bit variable in saftey critical application
Hi, I have doubt regarding bit fields in Keil C. Suppose I am having variable alaram:
bit Alaram=0;
Alaram=P0^1;
if(Alaram==1)
 produceAlaram();
whether there is any chance of bit toggling in the software....
whether the alaram bit will changed to 1 even the P0^1 is 0...is there any possiblility?
so I change the code as.
unsigned char Alrm=P0^1;
if(Alrm)
 Alaram=0xA5;
else
 Alaram=0xAA;
if(Alaram=0xA5)
 produceAlaram();
Alaram is changed to unsigned char so one bit change cant produce alarm erroneously...whether this approach is correct...if any mistake kindly tell me and give me some guidelines for programming safety critical application........
with regards,
G.Karthik Ragunath
