Hi all, I'm crossposting this from ST forum since i didn't get any response and the question is still open and becoming urgent in choosing the microcontrollore for our project.
I'm using the keil MCBSTM32 demoboard (F103RB micro) and I'm coding with the latest std_periph lib (V3.1.0 - 06/19/2009) with keil uVision 3 V3.85 and ULINK-Me. The board is powered from both the usb cable and the ULINK (ULINK is not supposed to power the board, but I've seen that even if the main usb power cabe is diabled the board is powered with just the ULINK connected).
The indipendent watchdog doesn't seems to work properly if the debugger is running. All seems ok if the debugger and ulink are off. Why ??? From the board schematics, the NRST pin is connected to both the board reset button AND the jtag connector.
Also, in this unclear situation, the undocumented function NVIC_SystemReset (taken from some FLASH protection example) does not works (it seems to block on the while(1) infinite cycle waiting for reset after setting the NVIC_SYSRESETREQ bit. Does this function relay on the IWDG to reset ? Anyone with similar problem ?
Hi Marco
Systemreset: I use the following code to request a systemrest out of unprivileged mode.
void __svc(1) PeriResetSystemSVC( void ); void __SVC_1 ( void ) { // note: beginning of protected function to reset the system __disable_irq(); // set software reset flag NVIC_GenerateSystemReset(); // hack: for debug endless loop should never be reached while( 1 ) { __nop(); } }
The differences are that the irq get disbaled and that I use an older version of the ST fimrware lib. But it isn't obviously to me, way your code isn't running.
Watchdog: Perhaps you have to disable the "run to main()" check box at the debug settings?
Hi Raphael,
1 SystemReset My code is much like your:
if (ProtectedPages != 0x00000000) { //bootloader pages are not protected, protect them FLASHStatus = FLASH_EnableWriteProtection(D_FLASH_BOOTLOADER_PROTECTED_PAGES); Led_1_Turn_On(0,0); //TODO TEST, remove when done // Generate System Reset to load the new option byte values __disable_irq(); NVIC_SystemReset(); } else { Led_1_Turn_Off(); //TODO TEST, remove when done }
But it doesn't work...
2) Watchdog I disabled the "run to main()" checkbox but nothing changed.
Can I ask you which board are you using (if you're using one...)
We use our own board. We use the SWD configuration and uLink2 for debugging and programming. The NRST pin is also connected to the SWD connector but the pin B4/TRST isn't connected as ST did at their eval board STM3210B.
