there's one pin depending on his level (high or low), the programm should / or should not transmit all the rs232 debug messages (printf()) to the hyperterminal.
How is it possible to use some #ifdefs | or is it much better to use a global variable?
#ifdef DEBUG_MODE //debug mode - transmit all msg to the hyperterminal #else //no debug messages #endif int main(void) { if(AT91C_BASE_PIOA->PIO_PDSR & 0x10) { /* -> transmit rs232 debug messages */ } else { /* do not transmit any debug messages */ } printf("only tansmit the msg if DEBUG_INIT is true"); while(1); }
best regards Tim
It isn't. Not for what you're trying to do. #ifdef is evaluated at compile time. They have no relation whatsoever to run time influences like port pin states.
You already have a global variable: that pin's state.
Thank you for your answer. Could you tell me how it would be possible to get the same behaviour using #ifdefs (without the information of the pin's state) at compile time?
That's right. But then I have to use for every possible rs232 message an if clause determining the pin's state (or the global variable)?
if(debug_global_var == 1) printf("next debug information");
That will cost time and increase the code size...
It isn't, because it can't be the same behaviour. It's reasonably easy to have a compiler switch that turns debug output on or off, but impossible to have one react to run-time events.
You want to write a function debug_printf() that does the check, then calls vfprintf() as needed.
You don't say! Seriously, though: it's pointless to worry about time or space efficiency after you've started using printf().
That's the point. So maybe it's much better to decide at compiler time if I want to see the debug messages or not (without of the use of the pin state). But how is it possible to do that with #ifdef?
The canonical method is
#ifdef ENABLE_DEBUG_PRINTOUTS # define DEBUG_PRINTF(args) printf args #else # define DEBUG_PRINTF(args) /*nothing*/ #endif /*...*/ DEBUG_PRINTF(("outch, that %s hurt!\n", symptom));
Note: the double parentheses are important.
Thank you for your time & information.
