I wired up a isolation transformer like this!
can i connect it to the processor? if i connected the secondary's togother and one primary to?
on the other primary I read the voltage with respect to ground i get? should i get zero, because the ground point should be isolated?
Thanks and Regards, Jai
like what?
what are you isolating?
can i connect it to the processor? not directly, the processor which one can not handle negative voltages.
