hi i am trying to interface an 16x2 lcd onto an arm7 board lpc2148. the pins i am using for the data is p0.16-p0.23 and for control signals ie rs rw e i am using p1.24 p1.25 p1.26 respectively.When i dump the following code nothing is getting changed in the display .can anybody help me out...i am attaching the code here ..kindly do the needful
#include<LPC214x.h> void init_PLL(void); void init_GPIO(void); void lcd_data(unsigned char); void lcd_cmd(unsigned char); void lcd_init(void); void delay(unsigned int); #define E 0x04000000 #define RW 0x02000000 #define RS 0x01000000 int main(void) { init_PLL(); init_GPIO(); lcd_init(); while(1) { lcd_data('A'); lcd_data('B'); lcd_data(96); lcd_data('d'); delay(0xffffff); } } void init_PLL(void) { PLL0CFG=0x00000024; // TO GENERATE 60 MHZ CCLK PLL0CON=0x00000001; PLL0FEED=0x000000AA;//UPDATE THE PLL REGISTER PLL0FEED=0x00000055; while(!(PLL0STAT & 0x00000400)); // CHECK WHETHRT THE CCLK IS GENERATED EXAXT VALUE PLL0CON=0x00000003; // CONNECT PLL PLL0FEED=0x000000AA; //UPDATE THE PLL REGISTER PLL0FEED=0x00000055; VPBDIV=0x00000002; //PCLK=1/2*CCLK } void init_GPIO( void) { PINSEL0=0x00FF0000; PINSEL1=0x07000000; IODIR0=0x00FF0000; IODIR1=0x07000000; } void lcd_init(void) { lcd_cmd(0x380000); delay(0xffffff); lcd_cmd(0x0e0000); delay(0xffffff); lcd_cmd(0x800000); delay(0xffffff); lcd_cmd(0x060000); delay(0xffffff); } unsigned int adjust_portbit(unsigned char c) { unsigned char j; unsigned int result; result=c; for(j=0;j<16;j++) { result=result<<1; } return result; } void lcd_data(unsigned char ldata) { unsigned int temp,z; temp=adjust_portbit(ldata); init_GPIO(); z=~temp; IOCLR1=z; IOSET0=ldata; delay(0xffffff); IOCLR1=RW; IOSET1=RS; delay(0xffffff); IOSET1=E; delay(0xffffff); IOCLR1=E; } void lcd_cmd(unsigned char lcmd) { unsigned int temp,z; temp=adjust_portbit(lcmd); init_GPIO(); z=~temp; IOCLR1=z; IOSET0=lcmd; delay(0xffffff); IOCLR1=RW; IOCLR1=RS; IOSET1=E; delay(0xffffff); IOCLR1=E; } void delay(unsigned int value) { unsigned int i; for(i=0;i<value;i++); { } }
void delay(unsigned int value) { unsigned int i; for(i=0;i<value;i++); { } } <end> How long is yo're delay? It is not acurate and can be a big problem. I have the assembler here;
//* The delay is in R0 FOR us DELAY //* THIS IS FOR 48MHZ //* YOU CAN USE THIS CODE IN YO'RE PROJECT AND MENTION ME DoUsDELAY P1 MOV R1,#11 ;R1 = 11 P2 SUBS R1,R1,#1 ;R1 = R1-1 BNE P2 ;Branch if not now nullified NOP ;A more delaying SUBS R0,R0,#1 ;R0 = R0-1 BNE P1 ;BRANCH if NOW NOT NULLIFIED BX LR ;GO TO WHERE YOU CAME FROM <end> Zeusti. Always yo're freind
what a mess professor, this is a little better (I think):
// time measurement in microseconds for an LPC2478 running at 72[MHz]. use for short delays only that depend // only on the speed of the processor. #define MICROSECONDS(x) (x*15) __asm void delay(int32u a_microseconds) { loop MOVS R1, R0 SUB R0, R0, #1 BNE loop BX LR } Usage: delay(MICROSECONDS(10) ) ;
using port no p1 24-31 for data bits and p0.12 13 15 for rs rw and e bits respectively..i am trying to display the characters in the code but nothing comes up on the display and neither the inituialization commands are working kindly help
#include<LPC214x.h> void init_PLL(void); void init_GPIO(void); void lcd_data(unsigned char); void lcd_cmd(unsigned char); void lcd_init(void); //void delay(unsigned int); //#define E 0x00008000 //#define RW 0x00002000 //#define RS 0x00001000 /*void delay()__arm { __asm { P1 MOV R1,#11 ;R1 = 11 P2 SUBS R1,R1,#1 ;R1 = R1-1 BNE P2 ;Branch if not now nullified NOP ;A more delaying SUBS R0,R0,#1 ;R0 = R0-1 BNE P1 ;BRANCH if NOW NOT NULLIFIED BX LR ;GO TO WHERE YOU CAME FROM } } */ void delay()__arm { __asm { MOV R3,R0 loop: MOV R1,#11 ;R1 = 11 loop1: SUB R1,R1,#1 ;R1 = R1-1 BNE loop1 ;Branch if not now nullified NOP ;A more delaying SUB R0,R0,#1 ;R0 = R0-1 BNE loop ;BRANCH if NOW NOT NULLIFIED BX LR ;GO TO WHERE YOU CAME FROM } } int main(void) { init_PLL(); init_GPIO(); lcd_init(); while(1) { lcd_data('A'); lcd_data('B'); lcd_data(96); lcd_data(0x95); } } void init_PLL(void) { PLL0CFG=0x00000024; // TO GENERATE 60 MHZ CCLK PLL0CON=0x00000001; PLL0FEED=0x000000AA;//UPDATE THE PLL REGISTER PLL0FEED=0x00000055; while(!(PLL0STAT & 0x00000400)); // CHECK WHETHRT THE CCLK IS GENERATED EXAXT VALUE PLL0CON=0x00000003; // CONNECT PLL PLL0FEED=0x000000AA; //UPDATE THE PLL REGISTER PLL0FEED=0x00000055; VPBDIV=0x00000002; //PCLK=1/2*CCLK } void init_GPIO( void) { PINSEL1=0xFF000000; PINSEL0=0x0000B000; IODIR1=0xFF000000; IODIR0=0x0000B000; } void lcd_init(void) { lcd_cmd(0x380000); lcd_cmd(0x0e0000); lcd_cmd(0x010000); lcd_cmd(0x800000); lcd_cmd(0x060000); } void lcd_data(unsigned char ldata) { IOSET0=ldata; IOSET1=0x00001000;//RS; IOCLR1=0x00002000;//RW; IOSET1=0x00008000;//E; IOCLR1=0x00008000;//E; delay(); } void lcd_cmd(unsigned char lcmd) { IOSET0=lcmd; IOCLR1=0x00001000;//RS; IOCLR1=0x00002000;//RW; IOSET1=0x00008000;//E; IOCLR1=0x00008000;//E; delay(); } /* void delay(/*any arguement if required) { P1 MOV R1,#11 ;R1 = 11 P2 SUBS R1,R1,#1 ;R1 = R1-1 BNE P2 ;Branch if not now nullified NOP ;A more delaying SUBS R0,R0,#1 ;R0 = R0-1 BNE P1 ;BRANCH if NOW NOT NULLIFIED BX LR ;GO TO WHERE YOU CAME FROM } */ /* void delay(unsigned int value) { unsigned int i; for(i=0;i<value;i++); { } } */
Mr Approving Zeusti,
Not sure about your comment style; but I like your code. Nice accuracy and really efficient.
vikas, why are you using 2 branch instructions when you can do the same with one? you're killing your prefetch cache...!
void delay()__arm { __asm { MOV R3,R0 loop: SUB R1,R1,#1 ;R1 = R1-1 NOP ;A more delaying SUB R0,R0,#1 ;R0 = R0-1 BNE loop ;BRANCH if NOW NOT NULLIFIED BX LR ;GO TO WHERE YOU CAME FROM } }
will this be fine
<quote> you're killing your prefetch cache...! <end>
no Mr Tameer.
it is a delay with delays calculated. kiled prefetch cache is part of the delay!
Plz do not be so upset .if you study YOU can learn.
Zeusti.
Always yo're freind.
every nonsense post of yours makes this charade better. please, do proceed....
vikas, can you make up a convincing argument as to WHY you need to decrement both R0 and R1? only one of them will do! you also forgot to backup the value of the changed registers in the stack, and to pop the old value from the stack when done.
plz mr tameer.
plz explain what you think is so bad with my code?
it works.
it does not need horible *15 macro !!!
always yo're freind.
but mr tameer.
yo're code still used R0 and R1 and did not pre serve?
does ARM calling convections need you to store R0 and R1?
the 15 factor was established for * a LPC2478 running at 72 MHz * measuring with a scope and a processor pin how long the delay actually is. the 15 constant would need to be changed in case another processor speed is configured. that is the reason it is embedded in a macro - changing platform only required one localized change that affects all instances where it was used.
if you look at one of my previous posts, you would see that I indicated that mistake already. there is no need to decrement more than one register. the need to preserve/restore R0 and R1 stems from the fact that the caller might assume a different role/value for these registers, hence delaying your code without maintaining their old value might break your software one the call returns.
poor mr tameer.
read the apcs.
mr tameer.
c macro for this is ok for beginer.
but Approved Zeusti is not afraid of assemble function!
I really believe you have no idea what you are talking about. either way, I did my best. Please stay away from * flight control systems * mp3 players * the weapon industry * anything life saving/mission critical.
stick to what you know: babbling on Internet forums...
<quote> either way, I did my best. <end>
plz dont do {time} critical assembler until yo've read apcs :)
Zeusti() { (void)("Always yo're freind."); }
