problem downloading program to flash
hi,
I recently purchased starter kit AT89OCD-01 + ATOCD51 with AT89C51RE2 uC working with keil uVision3.
when downloading the program into the the uC using the following command:
-device ATOCDTARGET -hardware RS232 -port COM8 -baudrate 19200 -ocd C51 -operation onfail abort memory 14 loadbuffer %H PROGRAM
the result is:
Device selection....................... PASS
Hardware selection..................... PASS
Opening port........................... PASS
Initializing OCD....................... PASS
Synchronizing target................... PASS
Reading Bootloader version............. PASS 1.2.0
Selecting Memory....................... PASS
Parsing HEX file....... PASS 01.HEX
Programming memory..... PASS 0xffffffff 0x00000
Summary: Total 9 Passed 9 Failed 0
but i've notice that the last line is not as it should be: "0xffffffff" instead of few Bytes or KB.
I've read all the documentation using the following configuration:
DEVICE:Use extended linker (lx51) instead of BL51
TARGET:code banking, 4 banks: start-0x8000 end-0xFFFF
OUTPUT:debug information, create hex file, merge 32k hexfile, hex-386
i've modified the files: L51_BANK.A51 & STARTUP.A51 as written in the pdf's.
once i succeeded and my simple program worked, but now i'm stuck again
maybe i'm missing something.
please help.
thanks in advance
Nir
