LPC2378 CAN semaphore bug
LPC2368 using RTX
I've spent several days tracking down a problem where the CAN would stop transmitting after a time period - usually after exactly 31845 packets - which is 0x5555.
I found that CAN_hw_tx_empty was returning CAN_TX_BUSY_ERROR, but then the CAN interrupt was never transmitting the message waiting in the mailbox.
Next I looked at the wr_sem semaphore, and found that the token count was increasing with every successful transmission. Eventually the token count was rolling from 0xFFFF to 0x0000, which would cause CAN_hw_tx_empty to fail. Now I see 0x5555 x 3 = 0xFFFF.
Next I found that the wr_sem semaphore was being sent 2 - 3 times from the interrupt runtine.
Looking at the CAN_ISR function it seems that the semaphore is sent every interrupt if the CAN TX hardware is free. This is a bug, because the interrupt is called for receive, as well as TX for the other controller.
  if (CAN1GSR & (1 << 3)) {
    if (isr_mbx_receive (MBX_tx_ctrl[0], (void **)&ptrmsg) != OS_R_OK) {
      CAN_hw_wr (1, ptrmsg);
      _free_box(CAN_mpool, ptrmsg);
    } else {
      isr_sem_send(wr_sem[0]);    /* Return a token back to semaphore        */
Adding an additional test for the type of interrupt fixed the problem:
// If the CAN has transmitted
if(CAN1ICR & (1<<1))
  // If the CAN hardware is ready to transmit
  if(CAN1GSR & (1 << 3))
    // See if there are any messages to send
    if(isr_mbx_receive(MBX_tx_ctrl[0], (void **)&ptrmsg) != OS_R_OK)
      CAN_hw_wr(1, ptrmsg);
    else
      // Release semaphore token
Hope that this saves someone else 3 days of their life.
