if(radio_data[APP_MOUSE_BUTTONS]==0x09) { } else if(radio_data[APP_MOUSE_BUTTONS]==0x0A) { }
how to modify the button to autoclicker? Thanks!
Post a more extensive problem description.
Have you built a mouse using a 8051? What interface?
A mouse that auto-clicks continuously would be unusable. So exactly when should the mouse auto-click?
It is a PS/2 interface mouse. when I left click it will do the autoclick, while i right click it will stop. Actually the left/right click i will use the buttons(SW1&SW2) on the other board (nRF24LU1 Basic feature board) to instead.
The wireless mouse can work. just need to modify the left and right click(0*09/0*0A)
What "autoclick"?
wireless mouse autoclicker
You still haven't explained what you mean by "autoclick" or "autoclicker" here.
What, exactly, is the functionality that you require?
If you can't clearly, precisely, and completely specify what you want an "autoclicker" to do - then you are abviously going to have trouble implementing it!
Once you have a clear, precise, and comple specification, you should find it easy to implement...
Maybe the simplest solution would be to put some acupuncture needles into your fingers.
Then, when you want autoclick, you put one finger on the mouse button and, with the other hand, gently flick the needles. That will make your finger automatically pulse the button.
Hey Sausage man,
You remember you admitted a while ago that you were once nicknamed "crazed"? Well, this is one of those moments... :-)
I would put the mouse under my foot ad make my leg shake (I guess we all know how to do that)
Re what is an 'autoclicker' since the OP does not see the need to answer, I recall a thread some time ago on the same subject where the purpose was to win some computer game by having a device that could do 3 rapid clicks.
